Connecting two different networks to a control logix controller(L5561 )
danemotty
Apr 2011
abbeville, la
I am wondering what would be the best way to connect our 2 Process control networks to a new control logix controller (L5561 )
Can you install two ethernet cards in the logix controller and have different ip address'. For example
149.184.91.100
149.184.92.100
Therefore, if you lose the link to the 91 network, the 92 network would pick up the traffic?
149.184.91.100
149.184.92.100
Yes
I think success there is going to depend on the configuration of the other devices involved in this "traffic", but this should be possible with PC based communications.
149.184.91.100
149.184.92.100
As Okie says, yes. You can have a rack full of Ethernet cards if you want, without an issue.
It might be possible depending on sub-netting, if you are only messaging information back and forth. In that case, you detect a failure, and switch to a different set of MSG instructions to try and read off of the secondary network.
In reality, this is best handled with a router external to the PLC.
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
150
The drawing shows the basics of what i am trying to achieve. The Hall sensor is drawn accurately from a schematic from the supplier. It is...
1,209
If I have a PLC in machine A and I want it to give an input to machine B then I want to trigger an output in machine A based on the condition and...
1,573
I've seen projects using siemens (CPU315F-2 DP) and the programmers connected remotely from across the ocean. All the people at the machine had to...
4,593
Hello All, We have a DH+ network , with SLC500 Allen Bradley PLC.Also we have a HVAC unit using a Mitsibushi MELSEC FX2N-16MR PLC. I'd like to...
1,946
