Connection on dc motor gear with motor driver
EricaOng
Sep 2017
penang
I have problem on searching how to connect the dc motor model (SPG30e-20k) to my motor drive (L298n) and PLC ... can anyone help me? I searching google... they only teach how to connect to arduino...
dc motor got six pins :
pin 1 : motor - : output motor driver
pin 2 : motor +: output motor driver
pin 3 : Hall effect sensor vcc
pin 4 : Halll effect sensor gnd
pin 5&6 : output encoder
Hello, I am wondering how to connect between my CPUE05 port 2 (15pin) to a stepper motor that calls for B+,A-,GND connections. What type of...
1,637
Can someone explain how a Powerflex 525 drive interprets the PTC Thermistor signal from a motor winding? How does one know what the levels are or...
4,031
I have a 9 leads motor, I would like to wire it to Wye Start and Delta run connection. Can this be done? Thanks.
20
3,915
I am starting to use a wider range of motors and noticing not all motors come with connection terminals inside the terminal box (peckerhead for...
28
10,804
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/2093-in005_-en-p.pdf Do I need to make a DP15 connector cable to...
1,610
