COnnection problem Between Cp1612 2A and ET200S
all4here
Mar 2013
germany
hello.
i have one problem...this project work fine for one month and when i start the computer it works fine but now he show an error in the connection..
if i restart the system after that when i run the OPC Scout then i can not access the server of
OPC.
first i need to ping the ET200S after that i can access the OPC server and hardware.when i start the computer then it should work....why i need to ping...this is problem...please help me to solve this problem...
please check the image for more understand...
HI every one , I'm trying to connect two cpu's in siemens step 7 I followed all steps7 in this video https://www.youtube.com/watch?v=-qnvwz8nlRQ...
2,637
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,391
I have a problem in terms of inputs and outputs, when I create a tag for a variable% MW1 and I run it . i had a BAD display for my tag. So my...
4,566
Hello Everyone, I am being unable to connect my laptop & GE Quickpanel (IC754VGI12CTD) through an ethernet cable. But I could connect the same...
18
6,439
Problem with connection between TP170A and PROTOOL the project I'm trying to download for TP170A from configuration computer through Serial...
3,691
