Problem with connection between TP170A and ProTool
VITAL99
Mar 2011
Doha
20
Problem with connection between TP170A and PROTOOL the project I'm trying to download for TP170A from configuration computer
through Serial channel is enabled, a window " CONNECTING TO HOST...." appares but no project transfered
How do I make the connection between the PC and the TP170A? every one wellcome to resolve the problem Thank you.
Vital99
cable
What cable are you using ?
I recently had to download to an old OP17.
I've done this by USB converter to Serial. The connected cable on the converter was a Siemens 9 pins serial to 15 pins.
Problem was, Protool can only download to Com1 or Com2. My serialpor tha I had in the Device manager had adress Com3. If this is the case, then you must disable Com1 or 2 and change the Com3 to Com2.
If you have a PC with a serial port, without an USB converter, then you should not have much problems... Try 19200 bps or 9600 bps setting in Protool.
Kind regards,
Combo
Vital99
HI every one , I'm trying to connect two cpu's in siemens step 7 I followed all steps7 in this video https://www.youtube.com/watch?v=-qnvwz8nlRQ...
2,639
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,392
hello. i have one problem...this project work fine for one month and when i start the computer it works fine but now he show an error in...
965
I have a problem in terms of inputs and outputs, when I create a tag for a variable% MW1 and I run it . i had a BAD display for my tag. So my...
4,567
Hello Everyone, I am being unable to connect my laptop & GE Quickpanel (IC754VGI12CTD) through an ethernet cable. But I could connect the same...
18
6,442
