Connection problem between laptop and GE Quickpanel
The times when I have gotten a Error 6103, it is because I have the wrong model setup in the QP properties. Double check the Target's Model property against the actual Model number on the QP.
Part number is IC75VI12CTD So in PME I should select IC754Vxx12Cxx. That model number is selected in the target properties. When i get the error and i use either SHIFT+F3 or F4 it highlights the Compter Address in the propteries in the info viewer.
That is the wrong one for the IC754VI12CTD you need to select IC754VxI12Cxx, it's the "I" that says Intermediate, the "xx" is for the Loaded units.
Hey 'I is a noob', is that a .223 or .308 in your avatar?
Thanks Russ. I actually found this out by destroying the test project and starting fresh. When i added QP View/Control target it was an option that I didn't see last time.I have it working now, I just need to try to mimic the programming on this QP that i did on a RedLion a few months ago! Thanks you guys for all your input.
As for the rifle....no idea.
HI every one , I'm trying to connect two cpu's in siemens step 7 I followed all steps7 in this video https://www.youtube.com/watch?v=-qnvwz8nlRQ...
2,637
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,391
hello. i have one problem...this project work fine for one month and when i start the computer it works fine but now he show an error in...
963
I have a problem in terms of inputs and outputs, when I create a tag for a variable% MW1 and I run it . i had a BAD display for my tag. So my...
4,564
Problem with connection between TP170A and PROTOOL the project I'm trying to download for TP170A from configuration computer through Serial...
3,690
