contacts
Physical NC contacts open when the coil to which they're attached is energized.
NC contact instructions in a PLC go to the FALSE state when the memory location to which they're addressed goes to the TRUE state.
The picture of a NC contact that you see on your computer's screen while you're monitoring the PLC program won't change to a picture of a NO contact unless you edit the program.
Hello guys, I will try to summarize my problem as follows Problem: ---------- I want to monitor the status (& also remote control) of a UL489...
3,318
Are 24VDC contacts for PB's allowed to be exposed? I have an application where a control panel was put in with the contacts showing on the back...
1,845
Good Morning , A co-worker installed a Allen Bradley MatGuard this weekend . They were not able to get it to work . He was using a MatGuard...
1,110
Is there an electrical code requirement that calls out the a need for an auxiliary contact in a field mounted disconnect? I have a customer that...
21
7,840
