Control logix messaging
As I sit here eating crayons Im thinking produce and consume tags are a different thing, Im sure Im wrong and missing something....Thanks for PDF link.
Messaging should be easy...
Simple rule used to always work...
Port, Destination
Repeat until found....
Not sure if there's anything that breaks that rule.
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,186
Let me know if this is possible. I have a Compact logix with a 10.206.100.10 ip address and I need to read data from it to a Control logix on...
2,387
I apologize if this has been asked before, but I didn't find anything right away. I am going to have a control setup with 2 L62 processors, one...
22,815
Hi, I am currently replacing 2 Siemens Series 7 PLC's with a Control Logix PLC. There is also a 3rd Seimens S7 PLC onsite that is not being...
13,065
I am having trouble with getting no control of my analog output signal. I am using the SCL function block to control my analog output. The logic...
253
