Messaging data from Compact logix to Control logix
grider75
Jul 2014
Illinois
56
Let me know if this is possible. I have a Compact logix with a 10.206.100.10 ip address and I need to read data from it to a Control logix on 10.206.36.9 ip address. Is this possible? I am getting error in my message instruction.
Comms path is set up as MCCP7A_CLX, 2, 10.206.100.10, 1, 0
Error code 16#0000_0204
There would need to be a router between the two since they are on different subnets.
If the subnets were both 255.255.0.0, then they would be able to directly communicate without a router.
I thought that might be a problem. The compact logix is in a packaging line that I am trying to get to. There is a bagger, palletizer connected on the same network. The palletizer has a NAT device in it that is on the 254 subnet. So, if I message the data I need from the bagger to the palletizer then message it from the palletizer to my control logix would that work?
I'm currently working on a messaging system and Ive been having issues with trying to message over a REAL Data Type from one PLC to another. Has...
1,284
Hello Ken Roach, Thank you for your quick reply , As informed earlier i want to read P&F Sensor data on Micrologic 1400 series B using MSG...
17
5,811
I have a project that requires messaging between two PLCs a few STRING, DINT, and INT values. We usually create something like a DINT[20] and...
3,320
Hi Experts, I hope I will get help here. I am using PTV with LCD display I also want to be able to view screens on my phone on the internet...
2,480
Need help getting a MSG from one data highway to another on PLC 5. One DH+ network is in one building and terminates at a desktop computer on a...
1,265
