creativepaper
I have a ControlLogix PLC (ver 16) controlling Powerflex 700VC drives over ethernet. At present I have 2 Powerflex700 drives but will increase this up to a total of 16.
I am using datalinks for torque control and drive temp/motor overload data and this works great.
I need to capture faults from the drives instead of trudging to the display. I have sucessfully used explicit messaging to capture a single parameter but I have not been able to get results with scattered reads. I have followed the examples in the the ethernet/IP manual and looked for othere examples (most only show explicit not scattered).
I could use explicit, but since each message refers to a single parameter and single drive, I envision it would get ugly.
