Control Logix Processor as E/IP Adapter
ndzied1
Aug 2002
Chicago, Illinois
2,857
Is it possible to set up a Control Logix Processor as an Ethernet/IP Adapter?
I have a device that I want to communicate with a CLX but the device can only be a scanner.
I don't think that there is a way to configure a ControlLogix to be a generic Adapter object over EtherNet/IP.
I've reviewed this a few times and there just isn't an Adapter object.
When I need to test a generic scanner, I reach for the Red Lion DSP-SX running its EtherNet/IP Adapter because it's compact and simple. The OpENer open-source adapter is another quick-and-dirty adapter that might be even better since you could run Wireshark on the target machine for analysis.
I don't think Prosoft makes an in-chassis module that is appropriate for this application. An AnyBus-X with EtherNet/IP Adapters on both ends might get your data where it's going, but it will be kludgy.
That what I was afraid of. My device is CoDeSys based and I believe they are coming out with an E/IP adapter interface in the next service pack so maybe that will be available soon.
Would you know if the ControlLogix can do Modbus/TCP? I can be a Master or Slave on Modbus.
You might have some luck with the right EDS file(s). Consuming a tag is fundamentally similar to typical scanner/adapter type Class 1 communications. The key is how to request the data to read - by tag name, as with a CLX produced tag, or with assembly instances, which is the usual way. The first time I saw this was with Schneider Electric EIP modules - adding the correct EDS files to the config allowed for specifying the tag name and it is then possible to consume the tag from the Logix platform.
Can your Codesys device use EDS files for configuration? My limited Codesys experience with EIP has always been using assembly instances but it may now be possible to specify an EDS file.
Rasperry pi?
The Pi runs on CoDeSys and suffers the same lack of adapter support as the Eaton PLC I'm working with.
Also, I would not put it into a real machine. I'm ok with it for demo and in-house science fair projects but not on a customer's machine.
I'm not sure about that but I believe we will be going with a Modbus/TCP converter module that writes to and reads from data areas set up in the ControlLogix.
So I have an interesting question. I work with sites that don't have controls tech's and wanted to know if its possible for a processor to be...
1,220
i'm looking to do 2 Control Logix Processor Upgrades in my plant. just after some general info as i have not done this before. i could engage...
3,111
Hey everyone, I'm taking on a project that requires me to take data from a dxf file (an AutoCAD drawing) and provide it to a control logix...
3,768
I am trying to find a little info on changing out a control logix processor We are going to change a l55 to a l71 I know the program has 16.21...
2,867
Is it possible to have two or several PanelView Plus communicating with one Control Logix processor on Ethernet network? This is a new project...
3,278
