Control Logix remote I/O rack on PLC-5?
Paul351W
Mar 2008
Northern Illinois
154
We got into a discussion at work the other day and someone said that they thought you could use a Control Logix rack with an RIO adapter card as a remote rack on a PLC-5 system.
Has anyone done this? We haven't started switching over to Control Logix systems yet, but we have a need for a good amount of I/O in a compact area that includes 120VAC in and out, analog out, contacts, TTL signals, and thermocouple inputs. Right now we're running a lot of wires through a boom connector and we're looking for a better option.
Also, does anyone know if there are PWM driver cards for Control Logix? I know some of the Micrologix controllers have them but I don't need another PLC.
I looked at Flex a bit, but I don't see any listing for 5vdc TTL inputs, and I have the potential to use 32 inputs of TTL from our data aquisition systems. If I did put in a rack or block I/O modules, I'd like to be able to hook all the signals I am currently passing through the boom to it to reduce wiring.
I am just wondering if anyone has ever used R.STAHL Remote I/O I.S 1+ with Rockwell AB Control-Logix 1756-L71, Due to the difficulty of running...
2,611
hi, does anyone know what is the recommendation internet speed to connect to controllogix?
1,801
Hello All, I am looking for an option to connect Beckhoff remotes I/Os to control logix L73 processor over ControlNet using Beckhoff coupler...
1,842
Im trying to add a remote rack to a plc with a 1756 controller i like to use flex I/O as the remote rack for space resons but dont know how to...
3,445
Hi All I did a search of the forum and I didn't find anything that I appeared to be about my issue. A little baskground first. All our machines...
16
9,658
