Control Of Hydraulic Proportional Valves
2rlp
Sep 2006
Mumbai
136
I have to design a panel using Delta PLC. I need to interface the PLC with a Hydraulic Proportional valve having the following specs.
24 V DC Max Pressure at 800mA and Max Flow at 800mA.
The Analog O/Ps cannot handle such currents, so how do I interface the Valve & PLC?
Thanks for your replies
Ron
There are 'amplifiers' that convert your analog signal to the corresponding signal what the valve needs. We use those in our plant to control the proportional valves with the 0-10V analog output of our PLC's. Normally the manufacturer of the valve have these standard as a accessories to that valve. You need to look what your analog signal is, when you order one.
Thank you for your reply. I have found that i could use a PWM output along with a SSR to increase the current rating.
In the attached picture, you can see a hydraulic schematic of our installation with a proportional valve (Atos) with integrated force control...
26
11,367
Hi, I am an inventor looking for a way to automate a block-making press I made out of a log splitter. It makes blocks for building homes from...
7,229
Hello everyone, I'm reaching out for assistance regarding a project I'm currently working on. Specifically, it involves a hydraulic system with...
413
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,919
Hi, I am about to start a project controlling a hydraulic ram using a Siemens S7-1200 controller. It will need to be quite steady control, by...
762
