control solenoid valves
You need interface or interposing relays. Run your solenoid power through the relay contacts, and fire the relay coil with the voltage that is used in your output card/contacts. Be sure to use a small breaker for each output so you don't take down the whole process if an output faults.
Hi All, Solenoid bank controls air to 8 cylinders. We used to able to move cylinder up and down by hand no problem but now there is a small amount...
2,435
Hello, I am trying to make an Automatic Coolant Dispensing station for my client. This unit will be stationed next to a CNC Machine to monitor...
56
14,534
Hi, I am currently working on a thesis on programming a basic process tank, I need to control the servo valve and solenoid valve so that the water...
4,821
Reaching out to the community. I have recently been tasked with trying to write an algorithm controlling yamada DP-20F-EX pumps with 2 external...
2,583
what do i need to buy to get this project to work. i have a pressurized oil line that feeds a piston. the piston controls a v-belts pulley...
1,600
