whats needs for solenoid control?
jaspittman
Jul 2006
ohio
what do i need to buy to get this project to work. i have a pressurized oil line that feeds a piston. the piston controls a v-belts pulley diameter. the pulley drives a belt driven air compressor. i want to be able to set the pressure needed with a dial and have a solenoid valve move the piston until the pressure in the air compressor matches the dialed amount. this is a low pressure high cfm compressor. the valve will only need to flow a very small amount of oil, but will need to be able to make fine adjustments to the piston. it must be a 12v dc system and i will monitor the air pressure with a analoge pressure sensor. would it be cheaper to use a proportioning 3 way valve or two on/off valves. do i use a pic or a plc. thanks.
Use a PID Controller
PID Temperature Controller. AKA, Process Controller.
Analog input and output.
Input is Pressure Transducer.
Output is Proportioning valve.
Dial is Controller setpoint.
so after a previous thread about the panelview 1200. I figured everything out that I needed to get working with it. I've got the RIO discrete...
1,599
Good Morning, I am building a panel that has 120VAC, 24VDC, 12VDC, and 5VDC, and was wondering if anyone had any ideas for wire colors. I have...
3,127
Hello everyone, So I need help setting up traps in Studio 5000. Disclaimer I'm an intermediate PLC programmer so I need lots of help and I need to...
2,364
Hi Replaced an faulty AI module (331-7KF02-0AB0). When Inputs connected smoke was rising from the card. Got afraid of sinking the whole node...
1,634
I have to put 3 UPS's into outdoor cabs. I thought of going with the ones that are used on Traffic lights and such but that is such overkill for...
2,549
