allscott
- Join Date
- Jul 2004
- Posts
- 1,332
This is a question for all of you OEM, integrator, freelance programmer folks designing control systems for industrial machines.
What determines the level of safety equipment that you specify for your projects. Is it usually what the customer asks for, what you feel comfortable with, or do you go be someone's spec (OSHA, ANSI, etc...)
I'm curious because I have seen some machines that our company has purchased at both ends of the spectrum. A 200 ton press without as much as two hand operation. All the way to a packaging machine with safety mats, safety light screens all tied to safety rated relay (with a door switch on a 120V panel that killed all power if opened) banghead
I would also like to hear any stories of designers who have ended up in court over the systems they have designed because someone got hurt.
As a final question, what does liability insurance for people in this field cost? I am considering doing a bit of freelance control system work and am worried about liability and insurance cost.
thanks
thanks
