Control Yamaha Servo Drive with Micrologix
irondesk40
Jan 2008
nc
630
Has anyone had any experience with controlling a Yamaha Servo Drive with a Micrologix plc. hate to ask so many questions but have a lot of projects and this site is very helpful to me. I know the new stuff is designed to be run with a Compact Logix Plc with the AOI instructions but the machine i am working on alreay has the Micrologix 1400. I did it about 4 years ago and used a Automation Direct Sure Servo unit. I think it was a 750 watt Servo controller system and i used Modbus with Messaging. With no more of a move that it makes it has worked great but looking at making some modifications and we thought about changing the motor part out to a Yamaha unit and motor controlling a linear slide type setup to accomplish the mechanical modifications that has to be.
Thanks for any advice.
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
42
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
218
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
422
