controlling inputs via wincc
ronsorage
Apr 2013
greece
hello,im making a project for my univercity.i have made the programming for controlling a garage door.ii have used up-down-stop buttons as inputs.the project works fine with plc sim(s7),but when i try to make a button so i can control the input from wincc ,its not working(i tried "on click","on press-release" commands to set or invert the bit but the input is not changing).am i doing something wrong?
Are you trying to change a Input with wincc?
Try using a Marker (M) and see what happens!!
Hello, Currently I am controlling the Powerflex 700H via Ethernet and everything is working well. The client is wanting Auto/Manual function...
1,862
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
498
Hello! I need to control a sinter moisture in a mixing drum. I have a moisture meter with analog output 4-20 mA connected to analog input of PLC...
4,669
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
115
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
183
