ControlLogix 5000 Structured Text
rigsha97
Jun 2009
I need to move values from a UDT to a new array.
Currently I am using:
HMI_BZ_PS[00] := XtrA_Bz1.PS;
HMI_BZ_PS[01] := XtrA_Bz2.PS;
HMI_BZ_PS[02] := XtrA_Bz3.PS;
HMI_BZ_PS[03] := XtrA_Bz4.PS;
HMI_BZ_PS[04] := XtrA_Bz5.PS;
But I have a lot of these to do. In the past I have been able to move large amounts of data using the following:
For i := 1 to 11 by 1
Do
OfflineDie_Zone_Heat_Cntrl.PS := HMI2CLx_REAL_OfflineDie_PS;
End_For;
I am wondering if there is a way to to add another variable to have it do the same function but to have it fill in number in the tag also:
HMI_BZ_PS := XtrA_Bz(b).PS;
The two ways I know to do what you are talking about one is:
A lot of work to redo your tag structure - use two arrays
The other I do not know if ST supports and that is concatenating strings, I have done similar to what you want in C# using this method, I assume its in VB also, but I do not know about ST - also this method might take more processing time it involves converting number to string, concatenating the string then making that string your variable name to equal the array element
Other than that its like Daba said in the linked post, big hammer method
Has anyone had any experence using structured text on a Contrologix 5000 L62 platform. We have a new factory coming on line and they have...
8,983
I'm attempting to read tags from a 1756L81E(FactoryTalk Logix Echo) controller using the PLC4J api. I have one read and one write bool setup in...
2,293
Hey All, I'm currently building a control system for a large building in a industrial setting. Doing lighting, vent, roof control, door access...
3,503
I know there's the DTOS Function, but I have a value of "35" that is really "0035", and that's how I want it converted. Looks like the function...
1,522
I am an Electric Engineer working as a maintenance engineer and manage some technician on the production hall now but in the past, I mostly focus...
3,555
