Controllogix adding motion to existing project
pauly
May 2002
South Wales,U.k
244
Hello all
I am adding a new SERCOS module to an existing Controllogix rack and two new axis to an existing Controllogix project on a customers' site. I have received a copy of the existing project and added the axis groups and axis information off line to do some tests. My question is, what would be the best way of adding the new axis groups,tags etc and motor information to the on site project? It is a brave person that downloads what is assumed to be an up to date copy don't you think?
Any ideas or thoughts are appreciated
pauly said:
...It is a brave person that downloads what is assumed to be an up to date copy don't you think?...
I would not say brave. I would say they are more foolhardy. You would surely, and at minimum, perform an upload first when onsite as a backup before downloading anything new into the processor.
pauly said:
...I have received a copy of the existing project and added the axis groups and axis information off line to do some tests....
I would also say that you should create a copy of what you've received and only work on the copy, leaving the original file as sent.
If you still have a copy of the "as sent" ACD project file then I would suggest you open it and go to...
Controller Properties>File
Here you can see when the project was Created and when it was last Edited or saved. This may give you an indication of when the last edit was performed on this project before it was sent to you.
You would like to think that a prudent customer would have uploaded a fresh copy from the processor before sending it to you. You would also like to think that a prudent programmer would request that the customer does exactly that. Then the prudent programmer does not have to guess whether the copy sent to them is current, or not. But I know that sometimes a customer might have backups but does not have the wherewithal to perform an upload.
pauly said:
...what would be the best way of adding the new axis groups,tags etc and motor information to the on site project?...
If there are any edits in the working copy, then the other way around might be quicker?
If you still think that the working copy might have some edits that you don't have then, when onsite, to check for differences, I would upload the project from the processor and perform a compare between it and your edited version using the Compare Tool. This should show up any basic editing someone may have carried out that may not have been in the copy sent to you. You can then transfer any edits found into your edited copy. It may be quicker to transfer "their" edits, if any, to your copy than the other way around. Once done, or if no edits found, then you can just perform a download of your edited copy. Once your hardware has been installed and configured then you should be ready to download.
If you want to preserve tag data values, while downloading your edited copy into the controller, then I would suggest you use the Data Preserve Download Tool. This will automatically save the current tag data values to a CSV file, perform the download, and then restore the tag data values from the CSV file back into the processor.
You would now have your edits, their edits, if any, and the preserved tag data values in the processor.
Regards,
George
Prudent customer/programmer
QUOTE]You would like to think that a prudent customer would have uploaded a fresh copy from the processor before sending it to you. You would also like to think that a prudent programmer would request that the customer does exactly that.[/QUOTE]
I agree with the above, but some sites struggle to get up to date wiring schematics. You can only ask for the latest copy of the project.
Yes, as I said, they don't always have the know-how or even inclination to get you the "latest copy" i.e. the working copy so you have everything before making modifications. They often just get you the "last copy" i.e. anything including last edit copy, last backup copy, or initial copy from OEM or installer.
So that's kind of what I meant...when asking for the "latest copy", make the distinction I've just made so "they" understand the difference and perhaps why it's important.
G.
when this happens to me I always
upload from the controller and then compare it to what I received
Any differences are discussed with the client and made to the download version
Rockwell has a compare function
I am trying to add three AB 1426-M6E Power Monitor 5000s to the Device Tree of my Control logix application. Processor is L62 v. 20.12 Logix5000...
1,730
We have a controllogix setup with 3 racks, and 14 racks of PLC5 using RIO cards. Here is my question. One of the PLC5 racks has a...
1,721
Hi guys, Is it possible to add new I/O point during online (Remote Run) in existing Remote Chassis via Controlnet? I want to use the existing...
2,304
I have a control logix network with a Logix5555 controller along with eight CNB modules at remote locations. Each remote location has various AI...
4,426
I have a ControlLogix 5555 controller (1756-L55). The system has no non-volatile memory. I’d like to try and update the system with non-volatile...
8,844
