ControlLogix - Alternative Comms via Reeling Drum
WillM
Mar 2015
England
46
I'm converting a SquareD Symax system to ControlLogix and I'm trying to pick the best solution for a reeling drum comms cable.
I've been looking at a new CAT5e reeling drum to keep everything on Ethernet/IP however there is a time proven reeling drum currently used which I'd like to use.
This drum connects 8030-CRM-210 Remote interfaces (https://www.artisantg.com/info/ATG7diwr.pdf) on the current system so will be a Belden 8723 cable (https://catalog.belden.com/techdata/EN/8723_techdata.pdf)
Is there a way I can use this reeling drum to get a ControlLogix rack to talk (As a remote rack) to another?
I have an application where one ControlLogix needs to read data from another ControlLogix. The second PLC is part of a validated pharma process...
2,920
I've got several identical machines at a customer's site. All of the CPUs are accessible from the corporate network. What I'd like to do is make...
4,316
65
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
89
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
223
