ControlLogix and Ramsey 9101 Integrator
ShadowFire
Mar 2016
Secunda
I would like to connect a Ramsey Micro-Tech 9101 integrator via Ethernet to a Controllogix Controller. I have tried using the Generic Ethernet Module but am not sure how to configure it. Could someone please assist?
79
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
231
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
214
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
253
