ControlLogix Cable
The_Wanderer
May 2003
Waterford, Ireland
96
Quick question ( I hope... ). I am working on a project at the moment with a Controllogix 5555 processor and a Panelview 1000 Touchscreen, both with RS232 ports. I am looking for the part number of the cable to connect them. My rep is on holidays, and the literature that I found only gives the connection from PC to each component...
Also, there is an ethernet bridge on the Rack (EBNT I think) that will be used to link the machine into the factory network at a later date. Can this be used to program the PLC and HMI (passthrough), or am I going to have to do that annoying bit where you switch cables and drivers whenever you want to program the other component?
Thanks for any help,
Jeff
Good Morning , I need to change the IP Address on a ControlLogix. Do I need to use the serial cable that I used the first time to setup the IP...
6,092
I am trying to use the RS-232 port (Channel 0) on my Controllogix processor to communicate with a device. I am trying to use the AWT command to...
5,089
Guys, It is about an AB ControlLogix 5555 processor communicating wth. a D-Net (Armor Block 1792D-8BVT8D) throgh a Flat Media Cable. Some of the...
7,610
85
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
