ControlLogix change run to program mode delay
Carvalho
Feb 2008
Setubal
Hello
I am working in a project where I use a processor 1756-L63, two ethernet cards 1756-ENBT/A to have a redundancy network with the supervision system and also have one module 1756-CNB/D and one 1756-DHRIO/C.
My problem is when I change the program from Run mode to Program mode appears the next message and the processor continuos in Rum mode only after 2 or 3 times try to change the mode just change.
I see and the description tell me this problem is related with the motion or message still executing.
Someone ever had this problem? How solved?
Thank you
Nuno Carvalho
The processor must complete or time out all communication messages before it will transition to program mode. If you have a continuous task, try increasing the communication time slice. Better yet, change the continuous task to a periodic task.
Is it possible to dynamically change Tag Names (in real-time) on these PLCs? I'm guessing the answer is "NO", right? Just externally, then...
3,892
Hello, Today I am trying to figure out the best way to write from controllogix to a plc5 only on change. The situation: - Migrated a Winview...
2,114
I usually make a master program that I then use on different processes where the only difference is vessel sizes and setpoint ranges. I have the...
2,193
Currently I use an MRP (Motion Redefine Position) to adjust position. Is there an SSV where I can directly change the absolute feedback offset...
1,947
Hello. What is the right procedure for online change of AI module configuration parameters (input range) with redundant AI modules (over...
2,491
