controllogix channel fault's meaning
That depends on the actual module, and how it's configured.
Some input modules can be configured to monitor wire-break (both analog and digital), and can have out-of-range alarms.
Output modules can monitor the on-board fuse or electronic trip circuitry.
The manuals are the best resource for interpreting the module status information.
112
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
110
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
239
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
231
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
263
