Controllogix clock
Prayder
Jun 2014
Arkansas
254
I created a Date_Time tag and polling the year,month,day, hour, minute etc. but they are all wrong. The year for instance is showing 1998. Is there somewhere I am supposed to go to get the processor to pull the current time from the workstation?
If the controller is not set to synchronize with an external source (like a NTP server) you need to manually provide the correct date & time.
Using RSLogix, go to Controller Properties > DateTime tab.
I have problem to set wallclock for controllogix by using SSV.
2,816
I read previous posts about this but have a question:Originally Posted by roadwhore In Rsview Open Global Connections Tab under System Enter PLC...
4,903
Does anyone know how a ControlLogix clock could be remotely set, from say a SCADA system ? Only GSV is available for the .DateTime attributes...
12,606
70
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
99
