Time sync PV 1000 to Controllogix clock?
elecmech1
Apr 2013
Lake Country
I read previous posts about this but have a question:Originally Posted by roadwhore
In Rsview Open Global Connections Tab under System
Enter PLC Tag for Remote Year,Month,Day Of Month, Hour,Minute,and second.
Enter PLC tag for Remote Date and Time.
When Remote Date and Time tag in PLC transitions from zero to non-zero value the Panelview will update it's internal clock based on the PLC tag values.
How do you make the Remote Date and Time tag in Controllogix PLC transition from zero to non-zero??? I have Controllogix with Panelview Plus 1000. I did everything in your description but don't know how to make the Remote Date and Time tag go high!!!
See orginal post below:
Explore the GSV instruction on the Logix PLC - thats what updates the tags that the PV will be monitoring. Note: the GSV wants to place the time and date data into an array of integers.
Ok, I am new to using PV+ HMIs. Here is my issue. I have two PV+ 1000 running on a system with a SLC 5/05 processor. All units are on ethernet...
4,700
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
63
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
138
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
234
Hello, I am trying to create an AOI that will retrive the clock datetime bits from a master plc through a generic message read instruction and...
503
