boiler-todd
Ok, I am new to using PV+ HMIs. Here is my issue. I have two PV+ 1000 running on a system with a SLC 5/05 processor. All units are on ethernet. The PV+ time that is displayed is what I set up in the terminal settings. I set one then walk over to set the other but the are off by whatever second it took me to thumb through all the menus to get it set and restarted. Now the PLC has its own internal clock that is also set. The problem is that all three are different. If a fault occurs with the PLC the fault history screen lists the PLC time for the fault but the PV+ sign could be off a minute or two. I know this is nit picky but the operator uses his PV+ clock for shift change. However, the PLC won't clear his counts for a few more minutes since they are not sync'd. This throws off our inventory numbers.
My long way to a question is - Is there a way to sync all three clocks to one time.
Thanks,
Todd.
Thanks,
Todd.
