Studio 5000 - Time Sync Grandmaster Priority - Control Sync and Module Connection Faults
Bobcat22
Mar 2024
North Dakota
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I did not build the program that I am working with and I have very limited support from the OEM that designed the equipment. I have a system using a compactlogix L27 PLC and two Kinetix 5500 servo drives, one of these drives frequently gets Control Sync and Module Connection faults. The drives are connected to the PLC directly via AB shielded ethernet cables. Researching these faults I eventually started looking into the time sync and noticed that the PLC is set as a slave and the grandmaster clock is defaulting to a PLC that is not on the same network as the one I am working with. The controller I am working with is the only controller that commands the two Kinetix drives, there are no other controllers in the application. I eventually thought to set the priority to a low number to make the PLC I am working with the grandmaster, this worked for a while but eventually it defaulted back to assigning this random PLC as the grandmaster. Originally the Priority 1: and Priority 2: were both set to 128. I changed Priority 1: to 1 and it still somehow sets this random PLC as the grandmaster. Does anyone know how this is possible and if I am going down the right path to eliminate the frequent faults and fix this or how I could potentially correct this issue permanently?
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
221
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
233
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
118
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
123
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
74
