ControlLogix Description Lost on upload
Ron Belward
Aug 2002
Oakville
Does anyone know how to restore RUNG Descriptions after they have been lost after an upload to a New without the original base file.
I can restore the TAG Descriptions from the base file by importing them back to the uploaded file, but the Rung Descriptions are not included?
RB
if you have an old copy of the program, if you try and upload over top of it, it will do its best to restore the descriptions I do believe.
Good luck
76
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
102
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
229
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
212
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
251
