ControlLogix: Field Wiring to Interface Modules
kandymann
Jan 2011
Virginia
168
Hello
I am putting an instrument panel together that contains:
1756-IF8H Analog Input HART Module x2
1756-OF8H Analog Ouput HART Module x1
1756-IB16D Digital DC Input Module x1
1756-OB16D Digital DC Output Module x1
***These modules are connected via prewired cables into 16 Point isolated interface modules with LEDs and Extra terminals (B1 and A1) for the DIGITAL I/O and the Analog modules are connected to the Analog Interface Modules with field side terminals (B1 and A1).
Questions:
1. Is the B1 terminals for current and the A1 for voltage? Cant find what terminals are for which.
2. When wiring the field wires to the terminals, there are two terminals for each point on the interface module. Can I just simply use the left terminal for the positive and the right terminal as my negative?
I just want to make sure that I have this thing wired correctly.
Thank you!!!
kandy: Please download manual 1492-td008 , look up for the cable and interfaces you´re using. It´s easy to find out how they have to be connected. In any doubt let me know.
I am looking at a project which I would like to use ethernet and would like to combine automation direct's field I/O with the power of...
2,939
85
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
231
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
215
