Controllogix import tags
NetNathan
Nov 2011
Corona, CA
2,199
I have 2 people doing Controllogix programming, they are doing different routines.
Now I want to to import the routines into the "core logic".
I have had no problem exporting and importing routines, but how do I import tags? I see export for tags but not import???
Thanks..
First time to import when I had an existing routine.
When I did the import I actually noticed all the nice information you get..
It asks you if you want to overwrite the existing routine, add to the existing routine, or change the name of the routine.
It shows you what tags are affected, if they will be added or changed.
It tells you how many rungs are being imported, deleted, or changed.
Of course....you can cancel the import also.
That's the XML-based Routine Import feature in RSLogix 5000, which was added in v17. It works both online and offline, and has been a huge time saver and error-preventer in my experience.
RSLogix 5000 is not built to be a multiuser environment, so the Routine Import is the method we use to manually fold together work done by various users at the end of the day.
Hi
This has saved me so much time as I would often import from other program's I have written and also I use it a lot for aoi
Donnchadh
I can't find out how to import the tags i created in rslogix 5000 (controllogix 5555 processor) into the Panelview plus 1000 operator panel. Does...
13,416
87
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
231
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
215
