Controllogix mave
Apr 2003
Toronto
151
I have a Mave instruction running but I do not see an Average all I see is 50 in and the same number going out, what am i doing wrong ??
INPUT = OUTPUT
In your photo the input number is the same as the output number. This implies that the input has remained stable for a while. If the input varies during time you should see the output changing but more slowly (however long it takes for 50 scans)
61
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
87
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
219
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
200
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
237
