ControlLogix or CompactLogix with MQTT
BeepBob
Jan 2023
Oakland, CA
107
Hello,
Have anyone here use Ignition to connect to a Remote IO using MQTT, then use
ControlLogix or CompactLogix to connect to Ignition using OPC UA?
How was your experience? easy to setup?
I am thinking of buying the Ignition MQTT module, made by Cirrus Link, to connect to 30 ish Emerson RSTI-OM
Do you want to ultimately connect the RSTI-OM to Logix?
Is the programming for the IO going to be done in Logix?
You can connect Logix tags and OPC tags to perform IO/Translation of one protocol to another as long as the OPC server supports it.
This manual also suggests that you can connect directly via OPC-UA: https://www.emerson.com/documents/a...ms-rsti-om-ip67-i-o-pacsystems-en-7632816.pdf
Why choose MQTT? Are you interested in the queuing capabilities?
Im new to Ethernet/IP so I expected some issues but I am not sure if what I am trying to do is even possible. I believe these 2 PLCs should be...
1,755
Hello! I'm struggling communicating a L320ER PLC through MSG Instructions, specifically I'm struggling with communication paths, I tried...
1,333
I've been looking at some of the upcoming jobs we're doing where I work, and I feel like the scale would justify a ControlLogix instead of the...
4,609
Client's Customer has an L64 v20 with MCI56-MCM Modbus in 2 slots. Client has an 1769-L16ER-BB1B v20 that needs to communicate with the L64 via...
2,289
Hi All, Fairly new to PLCs and in particular communications between processors. I'll explain the problem best as I can. I have a new water...
2,077
