Controllogix reading OPC data
rhill
Jun 2003
Stoney Creek,ON
42
We have a potential application where we need to read data directly from 6 GSE Torque Guns. The torque guns themselves act as OPC servers and we need to get the torque data into the Controllogix processor. Does anyone know if there's a way to do it without adding an external computer to collect the data and place it in the controllogix memory?
Any thoughts or suggestions would be greatly appreciated.
Rob
If you're talking about the same GSE eq. I just looked at online; you may be able to install a Profibus slave option. From there you can get a Prosoft module to talk Profibus.
Or since you know it will work on a PC but don't want to have one as another chunk of equipment to be a go-between; you could install a Prosoft PC56 in-rack PC and have it be the go-between. Hey-at least it'll be in the same chassis!
I just remembered-there's also a backplane driver available for the PC56 so once you have the OPC provided data from the torque guns, it may be possible to write that data across the CLX chassis backplane instead of through the ENET module...
Can anyone tell me the proper I/O address format to use for doing this? I've done this a million times with Modicon, but that driver doesn't...
5,499
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
254
Is this possible? I'm looking at the "Instruction Logic" of the AOI block (which is the *instance*, correct?) (a VFD AOI called "P_VSD"), and on...
1,568
Hi, is there a way to read a CSV or XML file into the Studio5000? Early phase of project and trying to avoid using Omron to read XML file (there...
3,220
I recently converted a PLC-5 program to Controllogix and using iFix as the graphic interface. I seem to have trouble reading a string and...
3,729
