ControlLogix Redundacy -Downloading Error
coreddl
Jan 2012
Singapore
Hi Mates, We have an 1756 L75 Redundant system (L75:RM:EN2TR:N2) in our plant and it was working well, recently it was powered up after a short vacation and I tried downloading a new program to the primary (primary already had one running) and i was notified with error in the RsLogix 5000 that Program cant be downloaded with secondary disqualified.
I noticed secondary RM shows "Disq" and its controller showed "No Project" and the primary RM showed "PRIM" and controller is running.After re-booting the controllers several times I got the secondary to SYNC and successfully downloaded the new project.
My question is> Is it not possible to download a new project to the primary controller when the secondary is Disqualified ? Any specific reasons!o_O
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
216
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
198
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
233
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
