I just want to add some more information with regard to tested/verified and recommended network topology designs which may be implemented for a Rockwell High Availability System (ControlLogix Redundancy) using Ethernet I/O...
ID: QA13697 | Access Levels: Everyone
ControlLogix Redundancy High Availability Ethernet System Testing
Please refer to the presentation (pptx) file at the end of the technote which was just released February 2020.
Note: While these DLR/PRP topologies are tested and recommended for implementation, other configurations may work, but there is a higher chance of failure during normal operation and Redundancy related events.
These design implementations are guideline recommendations only, and while I would assertively advise users to follow them, there are no stipulations as such which dictate that we must implement them. Rockwell will Support you where you have implemented a non DLR/PRP Redundancy topology, where the expected hardware or configuration functionality is not working correctly. All while under the advisement, of course, to move to a tested and verified design.
Regards,
George
Regards,
George
