Controllogix RMPS(ramp soak) function
pauly
May 2002
South Wales,U.k
244
Any body ever use the RMPS function in logix5000? Having used it with the emulator set up for 4 segments, it ignores the first(segment 0)goes to the last (segment 3)and holds. The hold part seems correct as far as the explanation is concerned, but I can't see how it can be reset to start at the first segment again and why segment 0 is ignored in the beginning.
Any ideas?
85
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
231
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
214
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
253
