ControLogix assemble two 8-bit words into a 16-bit word and visa versa
tmkkoservo
Nov 2010
Indiana
20
I have an application in which I am communicating with an Ethernet/IP generic module. The data exchange is 32 8-bit input words and 32 8-bit output words. The following is the requirement...
A single 16 bit value is represented as two consecutive 8 bit values. The ordering of bytes is
big-endian, meaning the most significant bits are placed in the lower memory location.
For example, to represent the value 1000 or 0x03E8 in hexadecimal, the lower memory
location contains 0x03 while the next memory location contains 0xE8.
Is this possible with ControlLogix? Can someone please provide me with an example? For example using words 1 and 2 to convert the input and also the output. Help is greatly appreciated.
Can anyone confirm that using contrologix 5580 controller is not possible to work with powerflex 527? It's been a couple of days now that i am...
1,205
Hello, I have a flow control PID that keeps locking up. It seems to control fine but after a while the output no longer moves. For instance...
972
Hi everyone, I can't add any modules to the Controllogix backplane and it doesn't matter online or offline. Both is not working. Please see the...
2,999
Hello, I have a question regarding the possibility of using messages instructions to communicate between: PLC5/80E Series D - CE Water Mark...
3,072
I have a customer who wants to control his DCS800 drives via Ethernet, so I have bought two RETA-01 cards. At the moment they are connected via...
1,008
