jerryd68
I have a system that i need to automate, I has a total of 7 refrigeration compressors, all with capacity control, the system needs to run based on suction pressure, if the pressure rises above the set point more capacity needs to be added, a total of 17 diffent stages, I need to be able to run any of the machines as the lead machine and add the capacity in sequencial order from that point, i.e if #5 machine is set as lead, then it would load, then start #6 machine, load it and so on. I have a contrologix monitoring the pressure and starting and stopping the compressors, I have a panelview plus as the HMI, any suggestions as to the easiest and most effective way to accomplish this would be helpful,
thank you all
thank you all
