Greetings everyone,
I'm currently working on a project where I've to convert an old Step 5 program with comments made in German into Tia Portal. The old program was downloaded from a [FONT=Times New Roman, serif]CPU 945-7UA1 .l-7UA2 [/FONT][FONT=Times New Roman, serif]and when done will be[/FONT] uploaded onto a CPU 315-2.
I've downloaded several manuals to help me out. However as I don't have access to any Step 5 PLC:s, it's not possible for me to start up the original program for testing purposes.
This leaves me guessing on how some of the instructions in the Step 5 program function, even after reading some manuals. I would appreciate if someone here could help me out with them.
I-stack
”[FONT=Arial, sans-serif]The interrupt stack (ISTACK) is an internal memory of the CPU where malfunction reports are[/FONT]
[FONT=Arial, sans-serif]stored. When a malfunction occurs, the appropriate bit [/FONT][FONT=Arial, sans-serif]is [/FONT][FONT=Arial, sans-serif]set.”
[/FONT]
In one block the program loads several of the ISTACK system data bits and transfers them to datablock 181, in order to have them displayed on the HMI (see a snippet of the code below).
[FONT=Courier New, monospace]OPN "DB 181"[/FONT]
[FONT=Courier New, monospace]L BS 102; // HEX-Code nicht vorh. Baustein[/FONT]
[FONT=Courier New, monospace]T %DBW196[/FONT]
[FONT=Courier New, monospace]L BS 103; // Adresse QVZ[/FONT]
[FONT=Courier New, monospace]T %DBW198[/FONT]
[FONT=Courier New, monospace]L BS 104; // Adresse QVZ[/FONT]
[FONT=Courier New, monospace]T %DBW200[/FONT]
[FONT=Courier New, monospace]L BS 203; // AKKU 1-H / ACCU 1-H[/FONT]
[FONT=Courier New, monospace]T %DBW202[/FONT]
[FONT=Courier New, monospace]L BS 204; // AKKU 1-L / ACCU 1-L[/FONT]
[FONT=Courier New, monospace]T %DBW204[/FONT]
[FONT=Courier New, monospace]L BS 205; // AKKU 2-H / ACCU 2 - H[/FONT]
[FONT=Courier New, monospace]T %DBW206[/FONT]
[FONT=Courier New, monospace]L BS 206; // AKKU 2-L / ACCU 2- L[/FONT]
[FONT=Courier New, monospace]T %DBW208[/FONT]
[FONT=Courier New, monospace]L BS 207; // STEPADRESSZAEHLER -H / [/FONT]
[FONT=Courier New, monospace] Step address counter H[/FONT]
[FONT=Courier New, monospace]T %DBW210[/FONT]
[FONT=Courier New, monospace]L BS 208; // STEPADRESSZAEHLER -L[/FONT]
[FONT=Courier New, monospace]T %DBW212[/FONT]
[FONT=Courier New, monospace]L BS 209; // DBA-Register -H[/FONT]
[FONT=Courier New, monospace]T %DBW214[/FONT]
[FONT=Courier New, monospace]L BS 210; // DBA-Register -L[/FONT]
[FONT=Courier New, monospace]T %DBW216[/FONT]
[FONT=Courier New, monospace]L BS 211; // BR-Register -H (RS-Reg)[/FONT]
[FONT=Courier New, monospace]T %DBW218[/FONT]
[FONT=Courier New, monospace]L BS 212; // BR-Register -L (RS-Reg)[/FONT]
[FONT=Courier New, monospace]T %DBW220[/FONT]
[FONT=Courier New, monospace]L BS 213; // DBL-Register[/FONT]
[FONT=Courier New, monospace]T %DBW222[/FONT]
[FONT=Courier New, monospace]L BS 214; // STATUS-Register (Condition Code)[/FONT]
[FONT=Courier New, monospace]T %DBW224[/FONT]
[FONT=Courier New, monospace]L BS 215; // Klammerstack 0 / Nesting level 0[/FONT]
[FONT=Courier New, monospace]T %DBW226[/FONT]
[FONT=Courier New, monospace]L BS 216; // Klammerstack 1 / Nesting level 1[/FONT]
[FONT=Courier New, monospace]T %DBW228[/FONT]
[FONT=Courier New, monospace]L BS 217; // Klammerstack 2 / Nesting level 2[/FONT]
[FONT=Courier New, monospace]T %DBW230[/FONT]
[FONT=Courier New, monospace]L BS 218; // Klammerstack 3 / Nesting level 3[/FONT]
[FONT=Courier New, monospace]T %DBW232[/FONT]
[FONT=Courier New, monospace]L BS 219; // Klammerstack 4 / Nesting level 4[/FONT]
[FONT=Courier New, monospace]T %DBW234[/FONT]
[FONT=Courier New, monospace]L BS 220; // Klammerstack 5 / Nesting level 5[/FONT]
[FONT=Courier New, monospace]T %DBW236[/FONT]
[FONT=Courier New, monospace]L BS 221; // Klammerstack 6 / Nesting level 6[/FONT]
[FONT=Courier New, monospace]T %DBW238[/FONT]
[FONT=Courier New, monospace]L BS 222; // Klammerstack 7 / Nesting level 7[/FONT]
[FONT=Courier New, monospace]T %DBW240[/FONT]
[FONT=Courier New, monospace]L BS 223; // Klammerstackpointer / Nesting level pointer[/FONT]
[FONT=Courier New, monospace]T %DBW244[/FONT]
[FONT=Courier New, monospace]L BS 225; // BSTACK-Pointer -H[/FONT]
[FONT=Courier New, monospace]T %DBW246[/FONT]
[FONT=Courier New, monospace]L BS 226; // BSTACK-Pointer -L[/FONT]
[FONT=Courier New, monospace]T %DBW248[/FONT]
[FONT=Courier New, monospace]L BS 227; // Anwender-Interrupt-Maske[/FONT]
[FONT=Courier New, monospace] User interrupt-mask[/FONT]
[FONT=Courier New, monospace]T %DBW250[/FONT]
[FONT=Courier New, monospace]L BS 228; // Unterbrechungs-Anzeigenwort[/FONT]
[FONT=Courier New, monospace] Interrupt condition code word[/FONT]
[FONT=Courier New, monospace]T %DBW252[/FONT]
[FONT=Courier New, monospace]L BS 229; // letzte gueltige Kachelnummer[/FONT]
[FONT=Courier New, monospace] Last set page number[/FONT]
[FONT=Courier New, monospace]T %DBW274[/FONT]
[FONT=Courier New, monospace]//;[/FONT]
[FONT=Courier New, monospace]L BS 32; // Anfangsadresse des internen / ?[/FONT]
[FONT=Courier New, monospace]T %DBW276 // RAM-Speichers eintragen / ?[/FONT]
[FONT=Courier New, monospace]L BS 33;[/FONT]
[FONT=Courier New, monospace]L %DBD208[/FONT]
[FONT=Times New Roman, serif] My question is, if it's possible to extract the same or similar ”malfunction report data” on the CPU 315 and have it displayed on an HMI?
Operating System Services in OB250
[/FONT]
[FONT=Times New Roman, serif]"The operating system services allow you to:
[/FONT]
[FONT=Times New Roman, serif]- Activate different operating system functions or[/FONT]
[FONT=Times New Roman, serif]- Change specific parameters during cyclic operation"
System service 28 is called during a start-up (now OB 100). One manual mentions the following about this:
”Operating system services 27 and 28 can be used to change the block identifiers in the RAM to"valid in EPROM" or "valid in RAM".[/FONT]
[FONT=Times New Roman, serif]System service 28 Change block identifier to "valid in RAM"
Changing of the identifier to "valid in RAM" changes the identifiers of all user blocks.”
I don't understand what this means. What happens to the blocks which are stored in the CPU:s RAM? Furthermore the instruction, when called, is commented by this in the original program;[/FONT]
”[FONT=Times New Roman, serif]Umschreiben der Bausteinkennung / Reconstruction of the block identification EPROM -> RAM”[/FONT]
I-stack
[/FONT]
[/FONT]
[/FONT]
