Convert analog current to analog voltage input?
>>>j<<<
Oct 2021
USA
Hello
My analog sensor outputs 4-20mA only.
My analog PLC input sees 0-10V only.
How can I make this work?
I tested out a different sensor that can switch between an analog current output and an analog voltage output and the PLC could see the change in analog voltage.
Thanks!
Ohms and Watts law stuff
A quarter-watt resistor cuts it kind of close. Cool resistors tend to be more stable - I'd use a 1-watt for this.
Remember that the PLC will have to be rescaled with a 500 ohm resistor to allow for 2 volts instead of 0 volts at the bottom end of the range.
Ideally you want a 1 Percent or better precision resistor. The analog reading accuracy can be no better than the resistor value - unless you tweak the scaling to match your installed resistor.
Hi; I need to monitor and log the 3phase AC input voltage for which I need a device to convert AC input voltage (say 350 - 440V) to analog (0-10v...
1,376
Greetings all, In a project I'm working on, we have an 4-20ma temperature transmitter linked to an S7-1200's analog input (0-10V reading 2-10V...
1,728
I need a good idea to solve a small task. My customer bought a measuring device where the measurement is collected by a controller from a...
3,245
Hi, I have a small LCP8 Linear Potentiometer I use to send analog values to my 90/30 GE Fanuc. I know that an analog value of 0.01426671 equals...
3,249
i have confused to convert high range and low range in analog input PLC... need your help, please i have pressure transmitter,the range beetwen...
2,925
