Converting 0-10v to 4-20ma
Lionel
Jan 2003
Good Morning Everybody
I am wondering if there is a way to convert a 0-5v / 0-10v to a 4-20ma signal. This will help me make a decision on the type of input option I should use.
hi
in our place we have done it the other wat around that is gone from 4/20 mA to 0-10V in this manner.
with a ct that gives a 4/20 output and putting a 500ohm resistor across the 4/20 mA then taking the 0-10V signal off each leg of the resistor.
////// 500ohm
/ ct / //
////// 4-20mA 0-10V
loop loop
I think thats right.
michael.
sorry aboutthe diagram.
but basicaly up end up with two loops one being the 4/20mA the other loop being the 0-10v. And by putting the resistor accross the 4/20
this gives us the 0-10v loop on the otherside.
I think the easiest and the most safe way is using an opto coupler (eg cny 17-3 )with a bjt (eg bc107) which can easily make the things happen accurately.
I have seen this kind of circuits very often used in voltage difference to current based communications if you want to have a predetermination you can see the circuit on http://www.runmode.com for s5 interface which is a rs232 com to s5 communication (which does have a voltage to current convertor) it needs a little change for the resistance to be comfortable for your use ....
It looks to me as if you have the 0-10 VDC signal and are trying to get it to a 4-20 mA. The previous examples are for going the other way - if you had the 4-20 mA and needed voltage.
If you want to go from analog voltage signal to 4-20 mA the easiest soulution is to use a signal conditioner. These are from $150 to $300 depending on features, power, etc. They are widely available - APi, M-Systems, Action Instruments, Acromag, many others.
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
229
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
138
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
366
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
401
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
784
