Converting Float32 to Actual Value
jjdizon17
Dec 2016
Taguig City
I am current connecting a Schneider pm5100 Digital Power Meter to a PLC using modbus connection, my prime objective is to get the actual Value of the Digital Power Meter and reflect it to SCADA. I got a problem in getting the actual value. I am getting this kind of DATA which has a lower bit and higher bit. Should convert it to get the Actual Value? or what formula should use? BTW I m using Micrologix1400 and RSLogix 500
dRiZcF
Which addresses are you Modbus values falling into
I think copy COP will do the trick
If it is 2 words
COP N15:0 F8:0 2 this should move the data into a float file and display it as such
it falling to an integer table. i am going 2 get byte for a single parameter for example. N11:0 and N11:1 are the modbus register for a parameter. My problem is I dont how to get the actual value using the modbus register
Try COP N11:0 F8:0 2
use any free F8 address
also is the value doesn't come out you will need to verify the bit order being sent out by the meter
depends on what you mean by decimal.
Decimal in the context of a plc is a base10 number
if you mean decimal as a fractional number that is what a floating point refers to while integer refers to whole numbers.
1 2 3 100000 8934892 are integers and we will assume decimal since no special identifiers were given.
1.0 2.0 1.1214 2.4242 are all examples of floating point numbers.
I think you have to use CPW instead of COP in the 1400. And, unlike the COP, where the length is based on the destination data element size, the length for a CPW will need to be based on the source address, so 2 times the number of floats
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
216
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
127
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
343
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
395
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
766
