converting seimens s5 to slc500
craig61
Oct 2003
hi
any out there have any information on converting seimens s5 to allen bradley slc500 as i am looking at converting these programs in our plant. any info on this subject i would be very gratefull
Craig61
I doubt it very much if there is any programs out there that will do this for you, so you will have to do it all manually. In other words, re-write the whole lot to suit the SLC500.
Good luck with the project.
Paul
Well, Paul, that's correct. I'm teaching both S5 and SLC500. In both courses I'm using similar or even equal project examples. While writing those courses I have been looking for a translation tool and I came up with nothing.
JesperMP wrote:
The bad new is, that not everything can be viewed/printed as LAD.
Well, if you're using STEP5 version 6 or higher, there's a lot more that can be represented in ladder than in versions 5 and lower. It's however not more than about 90%.
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
211
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
125
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
331
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
393
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
760
