Converting to RS Logics
jpd24
Mar 2003
MA
I recently hooked up to a SLC 500 and discovered that there was no rung or address comments.I talked to the manufacturer and he e-mailed me all the files for that machine. The problem is that it is not in RSS logics. How do I convert it over? Thank You
IS the file extension he sent .zip? or .rar? or gz?
If so use a program to decrompress files such as Winzip...www.winzip.com
The above means it a compressed file for sending by email
NOTE: RSlogix can also open files with .ach extension
If you have problems getting it converted I am open to send the file too and can send it back with .rss extension to work with.
Yeah, we're lousy guessers. You have to tell us what you need to "convert it over" FROM... :nodi:
beerchug
-Eric
Put the file he sent in a directory you can find.
Open up RSLogix. Go to File - Open
You will get an Open/Import Dialog Box
Look at the file type dropdown list. Choose the extension that matches your file.
Locate your file. Do what it says.
Use the imported file for the database, but if you try to go online and the logic differs it will ask you what to do. Merge the online logic with the description database, in case his logic isn't current.
I HAVE TO SAY THIS
I CANNOT BELIEVE IN CANADA THEY DONT REQUIRE ELECTRICIANS TO LEARN COMPUTERS.
Should be a LAW for it.
Do you have an offline copy of the SLC500 program? The rung comments and addresses are stored on the hard drive. If you're trying to get online with a different computer then you won't have the comments. You could move the offline file to the computer you plan on using to go online.
Re: I HAVE TO SAY THIS
Good one Ron, but the guy having the trouble is waving the stars and stripes......
technically this is in the wrong thread...loses something here
I think I had two (2) open at same time and replied to wrong one.
rss converting
Thanks Vetteboy,
The import/open file conversion worked like a charm.
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
229
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
138
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
366
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
401
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
784
