converting
ravi1821
Dec 2003
klang,selangor ,malaysia
24
dear sirs,
i am currently working on a project which requires to convert existing servo controlled mitsubishi plc to new q series. the real problem is that i am only changing the cpu unit and system will be using existing servo drive. the plc cpu is mitsubishi A171SH CPU unit and the servo drive used is MRJ2 100B. The system is configured in sscnet. i have less knowledge on this sscnet.
i would be very much appreciated if anyone could advise me on the configuration. we are planing to use mitsubishi q series cpu Q00UJCPU.
thanks in advance
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
222
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
132
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
357
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
399
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
779
