cooling plant room control ?
catalin78
Feb 2005
Constanta
115
I have to write some software to control the temperature in some rooms in a plant , in a room i have a pt 100 and a solenoid valve to the aircoolers that cuts the cooling agent if it's not needed , also i have control of starting the fans of the aircoolers , in some rooms are 1 unit with three fans or 2 units with three fans per unit . Each room has a preset temperature . Plc is siemens cpu 317 w profinet . I would like some starting ideeas if anybody had a similar application powered up .
Thank you a lot ,
Catalin
Done many many times
You could do it with a simple tempcontroller.
with a plc it is easy.
Watch the resoultion of the tempsensor it should be better as 0.1 Celsius.
How about defrost?
Check if fans are running
Temp control with on/off is easiest and you can set the limits, use separate for on and for off. Like 0.5 for off and 0.1 for on. do not use one setpoint with a deviation
if needed more just send mail
I'm sure you all have worked in hot, humid factories. I do, and probably will for a while now. Obviously the management doesn't want to spend...
2,149
I need to protect some pressure transmitters from hot (120°C) oil. Does anyone have a favorite transmitter cooling element/standoff they use...
173
Do you know a supplier for the following item? Similar parts and other brands are acceptable. cooling fan for servomotor mounting Rexroth...
1,367
Hi; We are working for selection of a rotary cut-off for our corrugator machine and getting quotations of different companies. A USA company...
1,719
I have to build a new cabinet to house a 22-inch touch screen, Mini PC, Panel Mount UPS, Ethernet Switch. It will be in an area that is extremely...
3,234
