Copying Screens from v15 to V12 TIA Wincc
bornwild
May 2010
Riyadh
429
hello all,
I have a project in Wincc V15 and I need to copy some screens from V15 to V12 TIA. How do I it. I cant copy paste as there are different Virtual Machines. Is there any way to do it by making the screens again.
It is simply not possible.
There used to be a "save as previous version", but I think it was V12 that was the last version that supported that.
Is the target a PC RT ? If not, and it is a comfort panel you simply upgrade the firmware on the panel.
WinCC Flex had a "save as previous", but I don't think Portal ever did.
Easiest solution would be to update the V12 project to V15. Updating Panel FW is recommended but optional, you can have a V12 panel in a V15 project.
Hello, I have a fairly complicated C-more screen that I developed in one project, but I want to use it in numerous existing projects. Talking...
1,622
I'm not super familiar with the Micrologix line of processors, but I am pretty familiar with RSLogix 500. I'm trying to simply copy a string to...
312
Hi All, I am looking to copy and paste a routine. I know this has to be done offline. My question is, when I go back online, these tags are...
567
Hello everyone, friends. I need help with something related to SCL. In a FB, I need to copy the value in the DB to the DB at another address. I...
1,389
Hello all! Is it possible to COP a SINT array to a UDT structured the same as a SINT array, except all BOOL bits? I have a module that has an...
3,180
