Copying tags in Productivity 2000
sparkie
Nov 2014
KS
1,148
I'm working in AD Productivity 2000. I have several identical stations I wish to copy the tags for and just change the station number. Now, there is no way to do this within the program, and I see that having to change the underlying system tag could be more difficult than just adding the tags in manually. Has anyone figured out a way to do this, or have some VB to take care of it?
I may end up writing my own to handle this task, but it won't happen on this project.
You can export, modify and then import. The System ID field, is where you want to be careful not to overwrite one already in use. If I remember right, when I did this, I just used numbers for the System ID that were so far away from any of the others, I could be sure they weren't in use.
Hello everyone, I'm working on something where I am retrieving data from a machine by sending it message packets and using the machine response...
1,964
I'm not super familiar with the Micrologix line of processors, but I am pretty familiar with RSLogix 500. I'm trying to simply copy a string to...
308
Hi All, I am looking to copy and paste a routine. I know this has to be done offline. My question is, when I go back online, these tags are...
560
Hello everyone, friends. I need help with something related to SCL. In a FB, I need to copy the value in the DB to the DB at another address. I...
1,388
Hello all! Is it possible to COP a SINT array to a UDT structured the same as a SINT array, except all BOOL bits? I have a module that has an...
3,176
