COROS OP15-C1 Upload (COM TEXT or ProTool)
mustbemad10
Nov 2011
UK
42
I have an COROS OP15-C1 (6AV3515-1MA20-1AA0) that I would like to get an upload of the program.
I don't know whether the project was written in ProTool or Com Text, so I wanted to try using Com Text first to see if it allowed me to upload it.
I have a copy of Com Text, but I have never used it before. How do I try to upload the project from the OP15?
In Com Text I have seen the options FD to TDOP, TDOP to FD & FD to FD. I can't find what these mean.
I have read that if ProTool was used then I won't be able to get an upload, possible only get a backup using ProSave. If that is the case then I will have to attack the problem a different way.
The OP-15 has a FM V2.30/1.
Appreciate some help on this.
Cheers ;)
I thought you could not upload from an OP15...
To attempt an upload, you would use TDOP to FD (TDOP - text display/operator panel and FD - "Floppy disk"... although this can be "hard disk" as well.
You have to choose the file location before attempting the upload, under SYSTEM menu, DRIVE (set to "C") and FILE (type in a name).
Hi, I'm working on migrating S5 to S7 and I have a COROS OP15 HMi. I need to know the tags from the OP15. I would be great help if someone can...
1,706
I need the program loading method (Step by step procedure)of PC->PLC and PLC->PC for SIEMENS Coros OP15. Any one please help me to do this...
4,656
Hi everybody I would like to ask you for an advice - I have a problem with connection between OP15 panel and S5 155U CPU 946. We had line that...
1,971
Is anyone have it pls send it to my e-mail.Thank for your help.
6,368
I need help about the op15 panel to upload the program from the one broken and then download that to new one which I have one already.As I know I...
1,873
